Munchkin Work in Progress
jalcoplumb_2
Member Posts: 172
Still trying to find a home for one of them.
Talk to you later,
Joe
Talk to you later,
Joe
New munchkin
Work in progress. 11 cast iron radiators. Removed the 2" mains and installed 1/2" pex to each off a RTI thermallock manifold. Max system temp 170.
The outside temp was 23 and the inside temp was 68.
I still don't have a t-stat hooked up it is just running w/outdoor reset. It has run for two days and maintained 68 inside temp.
The supply temp was 150 return 130. I will lower it because the contractor said it was to hot.0 -
Brackets?
What allthread mounting brackets are those? They look good. Good job by the way.0 -
Reposted for Eric.
It fell of the botom before you got to see it. I will try to get a few new photo's today and post.
I have the Super Store hooked up and running and the domestic water manifolds installed. I have been away form the job for a few days. Had a couple of emergency calls.
Joe0 -
hangers
just a standard split ring hanger w/ ceiling plate.
joe0 -
Just Curious
I didn't see the primary piping really good.
1. Are those radiators old?
2. Do you have a Y strainer attached to the Return?
3. If not you might consider putting one it so you don't clog up the Heat Exchanger.
Good Luck
JG0
