Cast Iron Boilers Repairs
Tim_15
Tim_15 Member Posts: 8
Does anyone know of a trick to weld or braze a cracked section on a cast iron boiler.Or is the only option replacement of that section with new
  • Mike T., Swampeast MO
    Mike T., Swampeast MO Member Posts: 6,928
    Been there, done that
    You might be able to find someone to braze the crack. I've seen it tried (unsuccessfully). Do some searching here and you'll find possible ways to braze but there are certainly no guarantees.
    Tried to replace a single section of a cast iron HX as well...
    Things had moved/distorted a bit over the years and the new section would not mate with the old. My advice would be to replace the entire HX or get a new boiler.
  • Andy Morgan_2
    Andy Morgan_2 Member Posts: 147
    Liability
    is the main reason not to attempt this. Are you willing to accept responsibility for the repair? If something major happens and the manufacture finds a repair job like this, they wil wash their hands of the situation, and it will be your problem. Chances are the crack was caused by a hot spot where there was no water in the section, IE mineral build up, etc. If you tried to repair it, it would probably crack again in a short amount of time. Try to find out what caused the crack, and then decide on changing sections or the whole boiler.
    Andy Morgan
    R. Morgan Mechanical, LLC
  • hr
    hr Member Posts: 6,106
    Most cast iron hx
    carry a 20 year warranty, or more. How old is the unit?
    hot rod
    To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"
