Tekmar house controler 371
Ricky A.
Member Posts: 2
Whatwould hapen to a 371 controler if you would jump out the RTU terminal 9 ,10,11 with a jumper wire only. insted of using the RTU unit 054 ? (term 9 =com. for RTU 3,4,5 ,Term.10 = RTU 3, term 11 = RTU 4 ).
tekmar 371
in place of instlling the rtu you should jumper this with 10K OHM resister wich you can pickup at an electronics supplies, supply house. this will simulate the rtu.0 -
The RTU is a 10 K resistor.
I'm curious why you would want to jumper these zones out?
Just put a RTU on the zones that you are using and ignore the others connections. Don't jumper them.
Steve0 -
Nada!
Can't do it.
Call tekmar tech support at 250-545-7749 and tell them what you're trying to do. Seems orthodox.
thank to all for your all in put.
Ricky A0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 946 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
