Tekmar house controler 371
Ricky A.
Ricky A. Member Posts: 2
Whatwould hapen to a 371 controler if you would jump out the RTU terminal 9 ,10,11 with a jumper wire only. insted of using the RTU unit 054 ? (term 9 =com. for RTU 3,4,5 ,Term.10 = RTU 3, term 11 = RTU 4 ).
  • Rudy Feddema
    Rudy Feddema Member Posts: 4
    tekmar 371
    in place of instlling the rtu you should jumper this with 10K OHM resister wich you can pickup at an electronics supplies, supply house. this will simulate the rtu.
  • Steve Eayrs
    Steve Eayrs Member Posts: 421
    The RTU is a 10 K resistor.
    I'm curious why you would want to jumper these zones out?
    Just put a RTU on the zones that you are using and ignore the others connections. Don't jumper them.
    Steve
  • hydronicsmike
    hydronicsmike Member Posts: 855
    Nada!
    Can't do it.
    Call tekmar tech support at 250-545-7749 and tell them what you're trying to do. Seems orthodox.
  • Ricky A.
    thank to all for your all in put.
    Ricky A
