Boiler runs for a longer time than needed?
S. Meredith
Member Posts: 5
My thermostat is set at 62 and the boiler comes on at that temp. But, it runs until it reaches 70 before it shuts off. Is there a way to have it come on more frequently, but run for a shorter period?
You need someone to look at it. Its not set up right? Your thermostat is not reading right? Somethings wrong, but toooooo many possible problems to know.
Steve0 -
Thanks for the response. I need a lot of tweaking on this system!0 -
could be...
... a bad/out of calibration theromstat, out of level thermostat (mercury type), mis-set or burned out (latter = bad thermostat) heat anticipator on the thermostat, or perhaps a sticking relay or control on the boiler, possibly something else. Probably something simple, but get it checked out.0 -
would the pressuretrol have anything to do with it? it's been set improperly at cut-in=2 and diff=1. I understand that could lead to a waste of fuel (such as longer running time?). (funny that the only people that have worked on the boiler are from the fuel oil company!)0
- 87K THE MAIN WALL
- 115 Chimneys & Flues
- 106 Geothermal
- 983 Plumbing
- 389 Solar
