MUNCHKIN BLOWER MOTORS
STUDENT
Member Posts: 8
HELLO, HAS ANYONE HAD PROBLEMS WITH THE MUNCHKIN 140M AMD 199M BLOWER MOTORS FAILING? DOES ANYONE KNOW THE CAUSE OF THIS PROBLEM? THANKS FOR ALL YOUR HELP.
have...
Not motor, but had a problem with air proving switch on 80M failing.0 -
199
The unit was installed Sept of this year and the blower quit (impeller broke off the shaft) last Saturday. I was told my new blower is an improved design over the one that failed.0 -
199M
> YOUR HELP.
199M
We have had 4 motors fail on us. Two have had the impellar break also. Thanks for the reply.0 -
True!
The new blowers are much "beefier" around the shaft and should prove trouble free in that dept. Also have gone to a molex connector for the control connection, this replaces an edge connector. Moles is easier to work with on the blind side of the motor. HTP is working on continious improvements to an already good product.0
- 87K THE MAIN WALL
- 115 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
