PETE`S PLUG
Gary
Gary Member Posts: 29
Looking for good gauges for the Pete`s Plug. Any leads welcome.Thank You
  • Jerry Boulanger_2
    Jerry Boulanger_2 Member Posts: 111
    Any good quality 1/2% accuracy
    gauge will work. I like Trerice #450 because the case is so strong and it has a blow-out back. I built a rig with a single gauge mounted in a 1/4" brass tee, and 2 - 18" compressed air flex hoses with gauge adaptors and ballcocks so that I can hook up to two test plugs at the same time and check the differential pressure on pumps, etc.
