PETE`S PLUG
Gary
Member Posts: 29
Looking for good gauges for the Pete`s Plug. Any leads welcome.Thank You
Any good quality 1/2% accuracy
gauge will work. I like Trerice #450 because the case is so strong and it has a blow-out back. I built a rig with a single gauge mounted in a 1/4" brass tee, and 2 - 18" compressed air flex hoses with gauge adaptors and ballcocks so that I can hook up to two test plugs at the same time and check the differential pressure on pumps, etc.0
- 87K THE MAIN WALL
- 57 Biomass
- 116 Chimneys & Flues
- 5.7K Gas Heating
- 109 Geothermal
- 70 Pipe Deterioration
- 990 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
