Pipe insulation
Bryan
Bryan Member Posts: 3
I am interested in pipe insulation for the headers and exposed distribution piping for a radiant system. I prefer not using any foam insulating products. The line sizes range from 1 1/4" to 1/2".
Thanks Bryan
  • Neil Fay
    Neil Fay Member Posts: 6
    Recommend that you use rigid fiberglass insulation (plumbing supply house). Comes in all sizes and wall thicknesses with sized plastic covers for fittings (ELs, Ts and 45s). The best price/performance appears to be about 1" wall thickness. Easy to cut and put up. No fiberglass particle discomfort. Recommend cheap miter box if you don't have one.
    Enjoy.
