Wirsbo 511S question
Dave_16
Dave_16 Member Posts: 51
Can anyone tell me what the 2nd dip switch is for on this control? One is for installer/user, what is the other one for??? I have a slab sensor connected to the control as well if that helps any. Any help would be appreciated. Thanks for your time and knowledge.
Frank
  • Ted_8
    Ted_8 Member Posts: 31
    Literature
    I think that you can down load the instructions at www.wirsbo.com
    Ted
  • Dave_16
    Thanks but..........
    The lit doesn't tell you squat, I have all the lit that came with the control and I have a password to get into the wirsbo site, It tells you nothing about the dip switch settings other then the 1 for installer and user. Thanks anyway.
    Frank
  • Paul Rohrs
    Paul Rohrs Member Posts: 357
    I stock that unit at work.
    I keep installation and operation instructions in a separate binder. I will post Monday, 1st am, and let you know.
    Regards,
    PR
  • Brian
    Brian Member Posts: 285
    511
    Try Giving Tekmar a call it's their design.
    Good Luck
    Brian
  • heatboy
    heatboy Member Posts: 1,468
    The second switch........
    has no function on the 511. It is used on the 512 for the second stage of heat or used for cooling. They share the same chassis and that's why the switch is there on the 511
    hb
    To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"
  • Tim Doran_2
    Tim Doran_2 Member Posts: 131
    Call Tekmar? Why wouldn't you call Wirsbo for tech supoport?
    As Jeffrey indicated in his post. It has no function on the 511 and is only there due to the shared chasis and pcb with the 512.
    Tim D.
  • Dave_16
    Thanks...
    I found that out when I called Wirsbo this morning. It sure would be nice if they told you that in the instruction book
  • hydronicsmike
    hydronicsmike Member Posts: 855
    Tim.
    You Rock!!
    Happy New Year!
