Wirsbo 511S question
Dave_16
Member Posts: 51
Can anyone tell me what the 2nd dip switch is for on this control? One is for installer/user, what is the other one for??? I have a slab sensor connected to the control as well if that helps any. Any help would be appreciated. Thanks for your time and knowledge.
Frank
Frank
Literature
I think that you can down load the instructions at www.wirsbo.com
Ted0 -
Thanks but..........
The lit doesn't tell you squat, I have all the lit that came with the control and I have a password to get into the wirsbo site, It tells you nothing about the dip switch settings other then the 1 for installer and user. Thanks anyway.
Frank0 -
I stock that unit at work.
I keep installation and operation instructions in a separate binder. I will post Monday, 1st am, and let you know.
Regards,
PR0 -
511
Try Giving Tekmar a call it's their design.
Good Luck
Brian0 -
The second switch........
has no function on the 511. It is used on the 512 for the second stage of heat or used for cooling. They share the same chassis and that's why the switch is there on the 511
hb
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"There was an error rendering this rich post.
Call Tekmar? Why wouldn't you call Wirsbo for tech supoport?
As Jeffrey indicated in his post. It has no function on the 511 and is only there due to the shared chasis and pcb with the 512.
Tim D.0 -
Thanks...
I found that out when I called Wirsbo this morning. It sure would be nice if they told you that in the instruction book0 -
Tim.
You Rock!!
Happy New Year!0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
