Copper Polish
Wayco Wayne
Wayco Wayne Member Posts: 615
guys use when you want to clean up a copper panel real pretty like. I've heard mention before but forget what was suggested. Many thanks in advance. WW
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=255&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"</A>
  • kevin coppinger_3
    kevin coppinger_3 Member Posts: 13
    i use 000...
    steel wool or scotch brite. Merry Christmas Wayne!
  • Dave DeFord
    Dave DeFord Member Posts: 119
    Go to your local motorcycle shop
    and get some Mothers Chrome polish or Simicrome(sp?) polish. There is also something that comes in a blue metal can that is basically cotton batting with some type of VOC (I think mineral spirits) and a very mild abrasive that works wonders on anything. Just can't remember the name of it right now. I avoid steel wool and scotbright as they tend to leave scratches on the finish that are hard to remove later. If your really want it to be shiny you might get some jewelers rouge and a felt or cotton wheel on a drill or dremel tool. Tons of work but it sure looks pretty when you're done. You might also look into white (not red) rubbing compound from your local auto paint shop.
  • Never-Dull
    From my days at sea.
    Noel
  • Dave DeFord
    Yepper..
    that the stuff. works great last long.
  • Mark Wolff
    Mark Wolff Member Posts: 256
    Grocery Store
    In the grocery store by the cleaning agents, there should be a polishing compound for copper pots and pans. It is the best that I've seen. Don't forget to spray your cleaned pipes with a high temp. lacquer so it stays pretty.
  • steve_6
    steve_6 Member Posts: 243
    Brasso
    It always works
