R-Value Question?
hr
hr Member Posts: 6,106
I have used is actually a laminate. The cork itself is very thin with a plywood type backer. If yours is this type the R value would probably be a tad less. Most cork I see is 5/16- 7/16" thick, probably a metric size!
1/4" rubber pad is r-.03 1/4" urethane 1.0. according to the RadPad. I suspect somewhere in that range would cover your product, depending on the makeup.
hot rod
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=144&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"</A>
