gas/oil conversion burners
Firedragon_4
Member Posts: 1,434
but a BTU, is a Btu, is a Btu, so all things being equal they can work at the same input level. The trick is flame temperatures and heat transfer, that's where oil excels.
If I was unsure today, I'd buy an oil boiler and put in a gas burner, then I can always go back and forth. The advent of dual-fuel burners in commercial applications has done wonders to prove the superiority of fueloil.
Any experiences
with boilers rated to use an oil or gas burner? I know a few makers (Biasi, Energy Kinetics) have specs for either an oil or gas burner on their boilers but in general, the 2 types of boilers are seperate product designs. Is there a big loss of efficency using a gas burner and are they more difficult to set up and tune? I would think a boiler designed for an oil flame pattern and heat ouput would not do as well with a gas burner.0 -
Joe, This is just my humble opinion. With the proper knowledge and tools both the Gas and Oil burners should be able to be set up and/or tuned without any difficulty. From an efficiency stand point Fuel Oil does have a higher BTU content than Natural Gas or Propane.
I hope that helps a little.
Your friend in the industry,
Alan R. Mercurio
Oil Tech TalkThere was an error rendering this rich post.
well it depends....
on the conversion burner. The midco ones the gas companies install are marginal at best. the riello ones are pretty slick...kpc0
- 167 Indoor-Air Quality
