MY RADIATOR IS BLOWING
KEVIN_13
KEVIN_13 Member Posts: 1
I HAVE A STEAM HEAT SYSTEM THAT I CAN NOT FIGURE OUT. I AM HAVING PROBLEMS WITH TWO OF THE RADS. ONE RAD BLOWS OUT AIR (STEAM) AS IF IT WAS GOING TO EXPLODE EVERYTIME I PUT ON THE HEAT AND THE OTHER RAD ONLY COMES ON IF I BLAST THE HEAT UP TO 80. I HAVE REPLACED THE VALVE ON BOTH BUT THEY STILL DO NOT WORK PROPERLY. I HAD A PLUMMER COME IN AND THEY TRIED TO TELL ME THAT THIS IS NORMAL. I HAVE 10 OTHER RADS IN THE HOUSE AND IT IS JUST THESE TWO THAT GIVE ME PROBLEMS SO IT CANT BE NORMAL.
ANY ADVICE.
