MY RADIATOR IS BLOWING
KEVIN_13
Member Posts: 1
I HAVE A STEAM HEAT SYSTEM THAT I CAN NOT FIGURE OUT. I AM HAVING PROBLEMS WITH TWO OF THE RADS. ONE RAD BLOWS OUT AIR (STEAM) AS IF IT WAS GOING TO EXPLODE EVERYTIME I PUT ON THE HEAT AND THE OTHER RAD ONLY COMES ON IF I BLAST THE HEAT UP TO 80. I HAVE REPLACED THE VALVE ON BOTH BUT THEY STILL DO NOT WORK PROPERLY. I HAD A PLUMMER COME IN AND THEY TRIED TO TELL ME THAT THIS IS NORMAL. I HAVE 10 OTHER RADS IN THE HOUSE AND IT IS JUST THESE TWO THAT GIVE ME PROBLEMS SO IT CANT BE NORMAL.
ANY ADVICE.
ANY ADVICE.
You're right, it's not normal
Your problem could have one or several causes. Your best bet is to go to the Find a Professional page of this site and locate someone near you who knows it isn't normal. If you're in the Baltimore area, e-mail me!
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"Baltimore, MD, USA
Consulting0 -
steam
is pesty huh? The system has to be looked at as a whole- there may be several problems causing this, or just on nasty one. Buy the Lost Art Of Steam Heating
PS- don't kill us with the caps! small case is fine
Gary
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"0
- 129 Chimneys & Flues
- 122 Geothermal
