Pipe cat
jim lockard
Member Posts: 1,059
the pipe cat for electricians (says it cuts 1/2,3/4,1" conduit and the outside diameter for 1" conduit is 1"3/8 the same as 1"CU anybody try it? Got get pass the $300.0 for another helpers toy.
Pipe cat
There is a new tool on the market. A battery operated cordless tubing cutter. Check it out at www.pipecat.com. Has anyone used these yet?0 -
SOB
I was just thinking about somthing like that about 2 mos. ago. Well, there goes another million.0 -
they
work really well, but it doesn't cut, or reem 1" pipe, it is only for 1/2 and 3/4 pipe.
it is very handy if you do a lot of smaller piping.
mine is
great, although seemingly lonely, so thinking of getting it a brother
Had it for 18 mos. what a time saver. Heard the price is coming down too.0 -
haven't
tried it, but it does have a reamer for the pipe ends.
although when I used the pipe cat at the trade show, you didn't need to reem the pipe ends. it cut the pipe without leaving a ridge on the inside of the CU pipe.
ebay cat
Best go have a look on ebay... #2591975985.0
- 87K THE MAIN WALL
- 115 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
