Pipe cat
jim lockard
jim lockard Member Posts: 1,059
the pipe cat for electricians (says it cuts 1/2,3/4,1" conduit and the outside diameter for 1" conduit is 1"3/8 the same as 1"CU anybody try it? Got get pass the $300.0 for another helpers toy.
  • John Lenhart
    John Lenhart Member Posts: 25
    Pipe cat
    There is a new tool on the market. A battery operated cordless tubing cutter. Check it out at www.pipecat.com. Has anyone used these yet?
  • sootmonkey
    sootmonkey Member Posts: 158
    SOB
    I was just thinking about somthing like that about 2 mos. ago. Well, there goes another million.
  • Bruce_6
    Bruce_6 Member Posts: 67
    they
    work really well, but it doesn't cut, or reem 1" pipe, it is only for 1/2 and 3/4 pipe.
    it is very handy if you do a lot of smaller piping.
  • Tony_8
    Tony_8 Member Posts: 608
    mine is
    great, although seemingly lonely, so thinking of getting it a brother :)
    Had it for 18 mos. what a time saver. Heard the price is coming down too.
  • Bruce_6
    haven't
    tried it, but it does have a reamer for the pipe ends.
    although when I used the pipe cat at the trade show, you didn't need to reem the pipe ends. it cut the pipe without leaving a ridge on the inside of the CU pipe.
  • Larry Weingarten
    Larry Weingarten Member Posts: 4,010
    ebay cat
    Best go have a look on ebay... #2591975985.
