Chimney Liners
Jim Davis
Member Posts: 305
The fact that most 80% furnaces put more heat up the chimney than an old furnaces because they do not add 50% dilution air would make one think liners shouldn't be needed. Many places they are required, someday they will be recalled and they fix nothing-just hide problems
Chimney Liners
Are chimney liners required for all 80% efficency replacement furnaces?0 -
Good idea
If you follow the National Fuel Gas Code, any chimney with outside exposure below the roofline should have a liner. Some instances, if the installation meets certain requirements on tile-liner sizing and water heater draft hood sizing, an inside chimney could get by without one though it is wise to use one anyway.0 -
More info is needed,what is the location of the chimney( inside the house or out side),is there a clay liner in the chimney,how many btus,is this a hot air furnace,how many units are vented into the chimney,what fuels,what maanufacturer furnace,what is your location,State please,it makes a difference,what materials comprise your existing chimney Oh yea the short answer is yes.0
