Trapped Water
Jim T
Jim T Member Posts: 4
I have two radiators on a steam system that are always banging, especially at night. I've cahnged the air vents, pitched the rads, checked the pressuretrol and even used a boiler cleaner. The return line is hung next to the supply line and does not have a main vent valve on it. Any ideas has to eliminate the water?
Thanks, Jim
