leaking weil mclain boiler
What is the model # ? and do you have a tankless water heater? Sounds like it could just be a tankless gasket leaking maybe. Anything is possible but I have never seen one leak like you said it is. Also on warrenty's never have had problems with M/W.
  • homeowner_2
    homeowner_2 Member Posts: 1
    my heating man tells me that my boiler has a leak by the hindge that holds the door on . it is only 8 years old .he tells me that he has seen this before and that i should replace the boiler .he also says that the mclain company gives him a hard time om warranty .can anybody help as a new boiler will cost a bundle. thanks
  • mph
    mph Member Posts: 77
    Leaky WM
    I've had two WGO boilers with cracks next to the hinge (I no longer install WM). The last one was just two weeks ago; had been installed for 8 years. WM admitted to a design flaw and sent us new boiler (without burner) at no charge. We billed the HO for installation.
    Jeff
  • Robert O'Connor_7
    Robert O'Connor_7 Member Posts: 688
    i too had one leak there as well, although i still use um. three years old and they made good for it.
  • Dan M
    Dan M Member Posts: 50
    weil
    I had a weil die after six years and they sent me a new one . I paid for the install.
  • Tom M.
    Tom M. Member Posts: 237
    I've replaced one
    and they didn't give me a hard time. I think the front section is heavier on series 3 (at least in that area.)
    Tom M.
