thermocouple failure
Boilerpro_3
Member Posts: 1,231
or hitting the thermocouple too low, you will burn them up. The thermocouple should be a dull red at most and the flame should hit the top 3/8 to 1/2 inch.
Boilerpro
Boilerpro
thermocouples.
thermocouple failure, last one lasted one week the one before one year,where can I buy a heavy duty one for a slant-fin gg125 hot water boiler. Thanks, Jack.0 -
Johnson Controls make
a nickel plated high ambient temperature thermocouple Model # K16RA. I would suggest also as Boilerpro has posted to make sure pilot is adjusted correctly. I would also do a combustion analysis to determine if you are having a poor combustion condition.0 -
measure the MV
Haven't you been to Timmie's school?
Gary
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"0 -
Too high
Slant fin used to mount their pilots very low because of the high combustion zone temps overheating the pilots. Check to see if some one remounted the pilot only on the top screw hole therby extending the thermocouple too highand causing overheating0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 984 Plumbing
- 389 Solar
