Are there any products to stop a leak in a steam radiator?
DaveC
DaveC Member Posts: 201
Are there any commercial products that will stop a leak in a steam radiator?
  • Tim Gardner
    Tim Gardner Member Posts: 183
    Where is it leaking? Are you sure the union and the valve are tight and that the vent is good?
  • Mark Eatherton1
    Mark Eatherton1 Member Posts: 2,542
    Yeah, but,,,,
    it will probably settle out in other places that you don't want/need it to...
    I you can see the leak from the outside, JB Weld epoxy will work. Surface must be clean and dry.
    ME
