Are there any products to stop a leak in a steam radiator?
DaveC
Member Posts: 201
Are there any commercial products that will stop a leak in a steam radiator?
Where is it leaking? Are you sure the union and the valve are tight and that the vent is good?
Yeah, but,,,,
it will probably settle out in other places that you don't want/need it to...
I you can see the leak from the outside, JB Weld epoxy will work. Surface must be clean and dry.
ME0
