reverse return problems
ed wallace
ed wallace Member Posts: 1,612
I recently repiped a burnham steam boiler that had a bad header set up i did a dropped header on it 1 rad was catching condensate in it even after it was pitched properly I installed a vapor stat now all is queit but takes for ever to heat up should i remove the dropped header or is there another solution ?
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=256&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"</A>
