wiring diagram
Boiler Guy
Boiler Guy Member Posts: 585
What is your problem with this monster? Can you provide a couple pics of the unit? If this is what I think it is the wiring is pretty simple.
  • John Lenhart
    John Lenhart Member Posts: 25
    wiring diagram
    I was wondering if anyone would have a wiring diagram for an old oil fired furnace. This is a powrmatic oil-fired hot air furnace high boy. Serial# C-0686 Model # CF350. It's a 1970's production. I contacted the manufacture and they said that they don't have any literature on a unit that old. Any help would be greatly appreciated . Thanks
  • Try over at
    www.oiltechtalk.com Alan Mercurio or George Lanthier (Firedragon) over there may have what you need.
  • John@Reliable_5
    John@Reliable_5 Member Posts: 76
    What are you trying to do?
    As Boilerguy said that's a very simple set-up, power in, fan-limit, cadcell relay, burner , blower.
  • John Lenhart
    Okay, My problem is the westinghouse relay that controls everything. The fan motor is 220 volt and the oil gun ia an abc 110 volt. It has a 24 volt transformer for the thermostat that controls the relay. I appreciate everyones help. Its turns out ,I found an old electrician up in the valley that has fiquired it out. Thanks everyone and have a merry christmas.
