wiring diagram
Boiler Guy
Member Posts: 585
What is your problem with this monster? Can you provide a couple pics of the unit? If this is what I think it is the wiring is pretty simple.
wiring diagram
I was wondering if anyone would have a wiring diagram for an old oil fired furnace. This is a powrmatic oil-fired hot air furnace high boy. Serial# C-0686 Model # CF350. It's a 1970's production. I contacted the manufacture and they said that they don't have any literature on a unit that old. Any help would be greatly appreciated . Thanks0 -
Try over at
www.oiltechtalk.com Alan Mercurio or George Lanthier (Firedragon) over there may have what you need.0 -
What are you trying to do?
As Boilerguy said that's a very simple set-up, power in, fan-limit, cadcell relay, burner , blower.0 -
Okay, My problem is the westinghouse relay that controls everything. The fan motor is 220 volt and the oil gun ia an abc 110 volt. It has a 24 volt transformer for the thermostat that controls the relay. I appreciate everyones help. Its turns out ,I found an old electrician up in the valley that has fiquired it out. Thanks everyone and have a merry christmas.0
- 86.7K THE MAIN WALL
- 54 Biomass
- 102 Chimneys & Flues
- 5.6K Gas Heating
- 102 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 66 Pipe Deterioration
- 934 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
