IN Floor Heating Tube
Richard
Richard Member Posts: 7
We are installing infloor heat in a car wash and the customer is suppling Zurn tubing. Has anyone used the tubing. In Anchorage we use Rehau and Wirsbo tubing.
Thank You
  • kevin coppinger_4
    kevin coppinger_4 Member Posts: 2,124
    I have used zurn....
    NON- barrier tubing for domestic water piping...It is PEXc silan crosslinking method tubing; wirsboand rehau are PEXa... Make for darn sure that it has a oxygen barrier. It may be a bit stiffer to work w/ than wirsbo...good luck kpc
