IN Floor Heating Tube
Richard
Member Posts: 7
We are installing infloor heat in a car wash and the customer is suppling Zurn tubing. Has anyone used the tubing. In Anchorage we use Rehau and Wirsbo tubing.
Thank You
Thank You
I have used zurn....
NON- barrier tubing for domestic water piping...It is PEXc silan crosslinking method tubing; wirsboand rehau are PEXa... Make for darn sure that it has a oxygen barrier. It may be a bit stiffer to work w/ than wirsbo...good luck kpc0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
