Defrost control
Have a lennox Hp 18 heat pump the Unit is old I tried to talk the home owner into a new unit but the condo is on the market and you know how that goes. The clock on the unit is shot I ordered a defrost timer and relay from lennox should get it this week has anyone ever install one.
Thanks
Anthony
  • David_5
    David_5 Member Posts: 250
    Timer
    If you ordered it from Lennox it should be the same as the old.
    David
  • Glenn Harrison
    Glenn Harrison Member Posts: 405
    Probaly get an electronic conversion kit
    I ordered a replacement timer for a HP20 about a year ago, and was sent an electronic defrost timer kit. all I can say is READ THE DIRECTIONS CAREFULLY !!!!!!!! I read the directions twice and still wound up making one wire connection error. You also may even have to install a 1/4" pressure tap (included) depending on exactly what unit you have.
  • John Mills_3
    John Mills_3 Member Posts: 221
    Don't bet on it!
    I went through what the other post found (actually kits not exact replacements are common with Lennox) and Lennox had a very expensive kit to replace the timer with a solid state board. Seems to me the customer said dispose of the old heat pump rather than put that kind of money in it.
  • Glenn Harrison
    Just remembered
    that I replaced the timer on a HP18 about 3 years ago ( was 30 degrees outside so my subconscience is trying to forget) and they sent me an electroinc defrost board kit that replaces the timer, pressure and temperature sensors, and adds a relay, requires wire modifcations all over the place including the exesting relay, and you will have to braze a line tap onto the unit for the new pressure switch. I believe I wound up charging over $500 for this and three hours+ of time. Probably won't be worth it.
    And as it turned out a year and a half later the outdoor coil blew out and the unit had to be replaced.
  • D lux_2
    D lux_2 Member Posts: 230
    go to grangers or
    johnstone supply see if you can get the same timer control
