Defrost control
Anthony Mobilio_3
Member Posts: 62
Have a lennox Hp 18 heat pump the Unit is old I tried to talk the home owner into a new unit but the condo is on the market and you know how that goes. The clock on the unit is shot I ordered a defrost timer and relay from lennox should get it this week has anyone ever install one.
Anthony
Anthony
Timer
If you ordered it from Lennox it should be the same as the old.
David0 -
Probaly get an electronic conversion kit
I ordered a replacement timer for a HP20 about a year ago, and was sent an electronic defrost timer kit. all I can say is READ THE DIRECTIONS CAREFULLY !!!!!!!! I read the directions twice and still wound up making one wire connection error. You also may even have to install a 1/4" pressure tap (included) depending on exactly what unit you have.0 -
Don't bet on it!
I went through what the other post found (actually kits not exact replacements are common with Lennox) and Lennox had a very expensive kit to replace the timer with a solid state board. Seems to me the customer said dispose of the old heat pump rather than put that kind of money in it.0 -
Just remembered
that I replaced the timer on a HP18 about 3 years ago ( was 30 degrees outside so my subconscience is trying to forget) and they sent me an electroinc defrost board kit that replaces the timer, pressure and temperature sensors, and adds a relay, requires wire modifcations all over the place including the exesting relay, and you will have to braze a line tap onto the unit for the new pressure switch. I believe I wound up charging over $500 for this and three hours+ of time. Probably won't be worth it.
And as it turned out a year and a half later the outdoor coil blew out and the unit had to be replaced.0 -
go to grangers or
johnstone supply see if you can get the same timer control
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"0
- 86.5K THE MAIN WALL
- 53 Biomass
- 95 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 156 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 928 Plumbing
- 6.1K Radiant Heating
- 384 Solar
- 15.1K Strictly Steam
- 41 Industry Classes
- 48 Job Opportunities
