Non Electric Zone Valve
Steamhead
Member Posts: 18,217
with much success. I even put them in my own house. Here's what one looks like.
That said- if this is an old gravity system that now has a circulator pump, the pump may have gone bad. This would only allow a small gravity circulation, which would go straight to the top floor. The cure would be a new circulator- go to
http://www.heatinghelp.com/newsletter.cfm?Id=125
to size the new one.
You could add the TRVs too even if the circ was bad, this would give you that much more flexibility.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=157&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
Consulting
Consulting
Non Electric Zone Valves
Anyone had any experience with these...
My issue is:
Three story house plus a basement. Hot Water Gas Boiler system with ONE Zone for all three floors...Thermostat is on second floor.
Second floor is comfortable, but third floor is unbearably hot.
I have two radiators on the third floor. I need to regulate the temp of those two radiators, but can not afford to put in another zone.
a couple..
of trv's will do the trick...try oventrop...go to fiainc.com...go to products...click on oventrop....kpc0 -
Many thanks...Now if I can just find someone on Center City Philadelphia to install a couple of these that would fix my problem...
Any Suggestions?0
- 167 Indoor-Air Quality
