Outdoor reset for steam...
RICHIE AMATO
Member Posts: 4
Which are the best controls for outdoor reset?
Clients gas bill is through the roof and thermostat placement is the in basement where the temps. reach 85 in three seconds flat.Please advise...
How do you lower the temperature of steam?
Vacuum. It would needto be a big building to be worth it.
http://www.mepcollc.com/VV.htm#mepco2
Timing the steam cycle would make more sense.
http://www.tekmarcontrols.com/products.html
http://www.heat-timer.com/?page=appover#steam0 -
see tekmar 269 post
See the posts for the tekmar 269 control.
Paul
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"Since 1990, I have made steam systems quiet, comfortable, and efficient. We provide comfort while saving the planet.
NYC RETROFIT ACCELERATOR QUALIFIED SERVICE PROVIDER
A REAL GOOD PLUMBER, INC
NYC LMP: 1307
O:212-505-1837
M:917-939-05930 -
relocate t-stat
Had a similar problem and relocated the stat to conditioned space above. WR stat with a lock out feature to prevent tenants from tampering also has set back for couple hours a night.customer has claimed dramatic improvments.Also check those main vents sure they're sized right not clogged0
- 50 Industry Classes
