Steam Heat HELP PLEASE!!
Eddie_2
Member Posts: 4
I have steam traps manufactured by Illinois Engineering Company. Can any one tell me where I can find replacement heat elements?
If not, can someone tell me where can replacement trap that will work without cutting up my hard wood floor in order to re-pipe?
Please help me by taking a look at some of the following pictures the dimensions are included.
Steam Heat help
If not, can someone tell me where I can find a replacement trap that will work without cutting up my hard wood floor in order to re-pipe?
Please help me by taking a look at some of the following pictures the dimensions are included.0 -
try barnes & jones........
they have replcements. Barnes@jones.com..kpc0 -
Eddie
As Kevin stated, Barnes and Jones does make replacement thermostatic elements for many Illinois steam traps. Most will also require buying a new cover. The URL, however, is different that what Kevin posted. Hope this helps.
www.barnesandjones.com
Glenn Stanton
Burnham Hydronics0 -
Thanks alot guys0 -
illinois trap parts are
available from one of our distributors. look up www.tunstall-inc.com this is response to eddie on a post of nov. 26th0 -
the photo indicates that the trap is an illinois "outboard", 1/2 size. the part number is listed on our website. any local wholesaler will be able to get these from us. regards, t.p. tunstall0
