Where can I buy Wirsbo tubing online
Hey Genius
Hey GOD
You have managed to insult every professional contractor that peruses this site, including the ones who have offered their professional opinions free of charge. Come on down to Alexandria VA., and I'll show you how to put in a radiant system. It takes more than book smarts to do what I do. (FLAG)0 -
I'm just curious
So you need 1600' of 1/2" pex for 4 loops. So, what circulator did you spec for 4-400' loops of 1/2" pex. What is your per loop gpm,pessure drop,heat output/sq.ft.panel area, SWT required. If you could share your design specifications based on your radiant anaylsis, you could be furthering the general knowledge base of the "paranoid" Professional contributors to this fine site, thereby reducing the potential for inadvertent "gouging" by the aforementioned. Your assertion that a $13,000 job was costed with $3000 worth of Material cost assumes you have an "insiders" view of Contractor costs. Is this the result of your priveleged information of the costs of "HASH"?
Jed0 -
sounds like
YOU couldn't be a subordinate. Are you afraid someone might know something your 185 doesn't ? Leave a pan of water out for a few days, what do you think is growing in it ? Drink it and find out. If you sucked up all this knowledge SO much faster than anyone here, must be you haven't enough work to do. Maybe you're spending all this time researching radiant heat while you're SUPPOSED to be working for your employer. Isn't that kind of like overcharging for services ? You get paid thousands to do a job, but don't, and do personal stuff instead.
You seem quite defensive for someone who has such vast knowledge. Some of the information that you present is flawed and raises the question of where it came from and what their motives are for telling you this flawed info.
As far as the "self serving jerks" comment, you came here for advice and help for YOURSELF. The jerk is the guy watching you shave.0
