Setting Thermostats
PLUMLOCO
Member Posts: 5
We have a Honeywell Programable, Should it be left at one setting all the time? Say 68% or can it be set as we have it now which means it starts up a 3:00 pm from 60% to 68% then down to 60% for the night. Then restart again at 3:00 pm. We hurry in the morning. What would be the most efficent for our steam system?
Jay, check this thread out...
http://forums.invision.net/Thread.cfm?CFApp=2&&Message_ID=62431&_#Message624310 -
setbacks and steam
Do you feel more comfortable at night with it cooler in the house?
And how's the system run when you do not set back, quiet & even heat? Noisy? Out of balance? Both?0 -
Night Time Heating
We sleep upstairs, so it is more comfortable to lower it. As far as noise goes it's not a problem. I'm just looking for the most effiencey from the system. I Dan's book he talks about stable temps and what happens with cold pipes.
Thanks,
Jay0
