hydronic tempering tank suppliers
hot_rod
hot_rod Member Posts: 26,645
Heat Transfer Products makes a nice one. 20 gallon, stainless steel capacity only. Virtually all the water heater manufactures can supply blank insulated tanks in many sizes. Larger sizes are available in ASME if neeeded.
I often a basic electric waater heater tank. Most have at least 4 connections, insulated with 1-1/2" of foam or better. Generally tanks 50 gallon or below have 3/4" taps. I use the 1" element holes for more capacity.
Here are a few of my latest tempering/ buffer tank installations. Hope this helps.
  • Lee B
    Lee B Member Posts: 1
    I'm tying a radiant floor zone into an existing how water boiler and plan to use a tempering tank and mixing valve arrangement. Problem I have is finding a good supplier for a tempering tank... preferably something that's factory insulated with multiple ports and of course, economical.
    Any good leads would be appreciated.
    Some ideas
    Heat Transfer Products makes a nice 20 gallon stainless tank. Four large connections, and some smaller control and drain ports.
    Most all the water heater manufactures can supply blank, insulated tanks in a variety of sizes and tap configurations.
    I often use basic electric water heater tanks, sometimes using the 1" element connections for better flow.
    The Clean Burn waste oil boiler has a 120 gallon Raypak tank slung below for a tempering/ buffer tank.
    Here are a couple of my most recent jobs. Hope this helps.
    hot rod
  • Uni R
    Uni R Member Posts: 663
    Hot Rod
    You have such nice curves!!!
