hydronic tempering tank suppliers
hot_rod
Member Posts: 23,860
Heat Transfer Products makes a nice one. 20 gallon, stainless steel capacity only. Virtually all the water heater manufactures can supply blank insulated tanks in many sizes. Larger sizes are available in ASME if neeeded.
I often a basic electric waater heater tank. Most have at least 4 connections, insulated with 1-1/2" of foam or better. Generally tanks 50 gallon or below have 3/4" taps. I use the 1" element holes for more capacity.
Here are a few of my latest tempering/ buffer tank installations. Hope this helps.
I'm tying a radiant floor zone into an existing how water boiler and plan to use a tempering tank and mixing valve arrangement. Problem I have is finding a good supplier for a tempering tank... preferably something that's factory insulated with multiple ports and of course, economical.
Any good leads would be appreciated.
Some ideas
Heat Transfer Products makes a nice 20 gallon stainless tank. Four large connections, and some smaller control and drain ports.
Most all the water heater manufactures can supply blank, insulated tanks in a variety of sizes and tap configurations.
I often use basic electric water heater tanks, sometimes using the 1" element connections for better flow.
The Clean Burn waste oil boiler has a 120 gallon Raypak tank slung below for a tempering/ buffer tank.
Here are a couple of my most recent jobs. Hope this helps.
hot rodBob "hot rod" Rohr
Living the hydronic dream0 -
Hot Rod
You have such nice curves!!!0
- 86.5K THE MAIN WALL
- 53 Biomass
- 95 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 156 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 928 Plumbing
- 6.1K Radiant Heating
- 384 Solar
- 15.1K Strictly Steam
- 41 Industry Classes
- 48 Job Opportunities
