steam boiler
sebast
Member Posts: 30
Boiler piping is perfect, but you should ramm that black magic marker down his throat. Sell him a $4000. car and write on the hood the date you sold it to him.
I just had my steam boiler replaced this is what it looks like did the guy do it right0 -
and this is the first floor
This is my tennants boiler. Is this one done right it's different from the other one0 -
from what I see...
looks piped well...I don't see any insulation...VERY important to have! kpc0 -
Both look OK
to me too. But Kevin is right about the insulation. And do those steam mains have vents at the ends?
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"All Steamed Up, Inc.
Consulting0 -
yes
Yes there are 4 vents0 -
yes
Yes there are 4 vents. 2 on each0 -
2 vents on each main
or one on each of 4 mains? To make sure they're right- how long is each steam main, and what pipe diameter? What vents are on each main now?
Consulting0 -
1 on each of 4 mains. They are vent rite # 35. The longest main is no more than 15 ft'. All of the mains are 2".0 -
whoever piped out these boilers is one damn good steamfitter.0 -
I gotta agree with you
He's done that before. I wish everybody's boiler were piped like that.
Noel0 -
Those vents might do OK
on such short pipes. They are about the same size as a Hoffman #4A, which will vent about 0.4 cubic feet of air at 2 ounces pressure. That 15-foot pipe contains 0.345 cubic feet. If all mains fill with steam in about a minute (measured from the time the boiler starts making steam) you should be OK.
Consulting0 -
thank you
just wanted to make sure0 -
Steam trouble
I can not get my radiators to heat, I have replaced the traps. I know that I have an air problem, but I do not know where to install air vents. The trouble is on one side of the building, and I get air out of the steam side of the radiators when I open the union.0 -
You might wnat to repost this as anew thread
Things tend to get lost way down here.
Boilerpro0 -
Stream Trouble
Stream Trouble
Stream Trouble
There should be a vent on the dry return
which is the return that runs overhead. If this vent goes bad, all the radiators feeding into that dry return will be cold.
Consulting0 -
$4000 cars have no hoods!!!0
