Slab Detail
ChrisL
ChrisL Member Posts: 121
Can someone tell me if there is any problem with having the vapor barrier on top of the insulation in a floor slab? The concrete guys first put down the foam insulation, and then put the poly over that. This floor slab is about 4 1/2' below grade in the midwest area. It has not been poured yet, and I'm not sure if its something that needs to be changed.
Thanks,
Chris
