Heat anticipator Q
GW
Member Posts: 5,183
Hi fella's,
Is it OK to see some dicoloration on the anticipator windings? I's assuming it OK as long as all the windings are intact- Thanks for any help,
Gary
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=171&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
Gary
Yes
If it is ok circuit wise. Some body may have shorted out the wires on the gas valve to see it they "Sparked" . That usually is enough to blow the anticipater wireing. It may have just got hot enough to discolor the windings. been there seen that0
