low loss header
can someone tell me what size the tappings are on a 120/80 low loss header - can't find it in the literature
Thanks
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=269&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
  • Ted_5
    Ted_5 Member Posts: 272
    Low Loss
    has 2" BSPT make sure you use sufficiant hemp and pipe dope on all four 2" pipe threads.
    Ted
  • Kritz_3
    Kritz_3 Member Posts: 85
    hemp
    What is the correct way to apply the hemp? Do you twist it
    into a string and put it on like lamp whick? Then dope over it?
  • Kritz_3
    hemp
    Steve
  • No, leave it loose
    and matt it over the threads. It'll stick to the pipe dope.
  • Steve Ebels
    Steve Ebels Member Posts: 904
    Hemp?
    We were thinking that stringy looking stuff was for recreational smoking!!! Your supposed to use it on the threads????? (g)
  • Mark Eatherton1
    Mark Eatherton1 Member Posts: 2,542
    My fine young German pipe fitting firend...
    Richard Graves of Heatmeister fame tells me he roughs up the threads with a hacksaw blade, applies a like coating of teflon paste dope, then drags the roll of hemp around the threads like tef tape dope, and he guarantees a tight joint.
    Is it legal to say hemp, roll, dope and joint in the same thread? Ya wanna bet that Ashcrofts people caught these threads and went "HMMMmmm..."
    "Whaddya plumbahs a bunch of crack heads or what!?!?":-)
    Some people never exhaled...
    ME
  • Mark J Strawcutter
    Mark J Strawcutter Member Posts: 625
    you also used the word \"drag\" (nm)
  • Wethead7
    Wethead7 Member Posts: 170
    Ashcroft's People
    Yes I saw the thread. The other's might not know what you are talking about. I and the A-G butted heads. He tried to fire me. That did not happen. So I spending time in Iraq. They can only keep me here for another six months or so.
    I have been wanting to back into retirement anyway.
    Mike
  • ScottMP
    ScottMP Member Posts: 5,882
    m
    cough, cough
