quantification of riser expansion
Tim Gardner
Member Posts: 183
How much does a riser of 1 1/4 black pipe expand? For example, is it 1/4" per 100"? More? Less?
Thanks,
Tim
Thanks,
Tim
The coefficient of expansion
for steel is 0.0000065" per inch per degree F. So, if a pipe is heated from 50 to 200 F, it will expand (150 x 0.0000065"), or 0.000975" for every inch of its length. If it is 100'(1200") long, that would equal a total expansion of 1.17". The diameter of the pipe has no bearing on this.0 -
Jerry
I hav'nt seen those enumbers since I took my Mass Plumbing exam.
Can you imagine trying to memories about five of those zzzzzzzz. Sure cure for insomnia
Scott
Thanks!
This is EXACTLY the information I wanted.
Many thanks,
Tim0
- 120 Geothermal
