Buderus direct vent
Rich_14
Member Posts: 17
Which is the best burner for the Buderus oil direct vent set up , the Riello BF or Carlin EZ ? Rich...
How about
What you are familar with and what is locally avalible, parts wise easily. Just thinking of the future!
burner
personaly i like reillos burner the best. they have had some problems with there post purge control. so for now i would use carlins burner. stay away from becketts af2 dosent work well in direct vent units
hope this help.
joe.g.0 -
Ditto ...
to what Joe said...Hi Joe! I have been bitten by the k7r pp control...Riello will eventually get it right..kpc0 -
riello has a new post purge control for direct vent that is now avaliable. carlin has had trouble with their air intake box. both are good burners. but i have found riello to be bulletproof in other applications. in either case use the areo cowl termination fitting not the field. to avoid contaminating the intake air.
I have installed many direct vent Buderus boilers.
Without any hesitation, I recommend a Riello BF burner and Aerocowl termination vent.0 -
the k7r pp
Does anyone wonder why there is NO RECALL on the K7R?0 -
Intake Problem
Mike , could you explained the problems with the Field system ? Has it been a reported problem or recall ? I would hate to loose the Field , it seems to be quiet over the Areo..... Thanks0 -
the problems....
I have had are Cross-contamination w/ the consentric design especially if the hood is closer to the ground. The Aerocowl wants 2 seperate openings. Seperate intake and exhaust less headaches...the Buderus rep. here in NH. tells installers directly to NOT use the Field hood. kpc0 -
Thanks........
.......for the heads up.0
- 167 Indoor-Air Quality
