alternating reciever
mike terry
mike terry Member Posts: 33
I installed the new water feeder today. I cant believe it took me so long to decide to replace it.simply because I wouldnt entertain the possibility that 2 shut off valves were leaking when closed off. ( they are in series). I took the caps off the checks also they are clean and functional.BUt I still have this air elimanator trap problem.I unscrewed the little brass piece out of the top which is nothing but a hole. I stuck a screw driver into the tapping feels like cast iron to me .I mean there were no obstructions that offered to fall away.What can I do with this thing?Im probably going the vaporstat route,Im running such low pressure IM sure my water is going to come back.I guess im saying I dont see the boiler return trap coming into play any more unless there is a pressure control prob or some body comes along and cranks her up.
Any thoughts? once again thanks to everyone who has takin time and energy to reply
Mike Terry
