Amana outdoor boiler
Dan_10
Dan_10 Member Posts: 1
Just inspected a house that had one of these. Very small heat exchanger running a working fluid loop to a liquid to water heat exchanger indoors. Working now but wonder if anyone has any idea of repairability or source of information or repair parts for likely problems of these systems?
  • John Mills_3
    John Mills_3 Member Posts: 221
    Well...
    Reliability, terrible
    Source of parts & support would be your friendly, local Amana distributor.
  • Dale
    Dale Member Posts: 1,317
    Cross yourself
    Maybe a few times and walk away. This is a better halloween post. This is the HTM idea that cost Amana millions and a great reputation. No " we service all brands" shops that I know of will touch these. There used to be one dealer in my area that would work on them but that was a few years ago.
  • john wood_2
    john wood_2 Member Posts: 2
    Was a great concept, but.......
    Have worked on a LOT of these. Some were more reliable than others. Average life of a good one was about 12 to 15 years. Parts are getting scarce and expensive. A great product to replace the outdoor sectoin with is the munchkin boiler. Just have to find a place indoors for it or build a "doghouse" for it so you can keep the condensate from freezing. A plus is that the munchkin will give a whole lot better efficiency.
