buried return
Steamhead
Member Posts: 18,213
to run a new wet return just above the floor. Just make sure it stays "wet".
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=157&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
Consulting
Consulting
any good reason
I can't replace it above the floor ? I think it may be contributing to water loss. HO says he fills boiler (no auto-feeder) 3-4 times a day, and it's not even COLD YET. I found 3 leaks in the boiler. This appears to be 2nd boiler as it's on blocks in a pit. Probably coal 1st w/ a Hoffman #1. As long as water line is at same height and loop seals are "wet", shouldn't it be okay ? Can't find reference to this in "Lost Art".
TIA,
Tony0 -
thanks
- 167 Indoor-Air Quality
