1/2\" PEX piping to 3/4\" Sweat
Eric G
Eric G Member Posts: 3
Hi! I'm hoping I can find some help here. I'm installing Buderus radiant panels in a house that had old floor baseboard. The baseboard had 3/4" Sweat piping. The Panels have 1/2" PEX connections. I have the 1/2" PEX to 3/4" Sweat fittings but need to know if there will be flow issues because of the reduced flow. Should I divert the flow in the 3/4" piping so that there is essentially a bypass that goes directly from the supply to the return? Or should I really not worry about it? There are 3 radiant panels on this one-pipe circuit.
Thank in advance!
