1/2\" PEX piping to 3/4\" Sweat
Eric G
Member Posts: 3
Hi! I'm hoping I can find some help here. I'm installing Buderus radiant panels in a house that had old floor baseboard. The baseboard had 3/4" Sweat piping. The Panels have 1/2" PEX connections. I have the 1/2" PEX to 3/4" Sweat fittings but need to know if there will be flow issues because of the reduced flow. Should I divert the flow in the 3/4" piping so that there is essentially a bypass that goes directly from the supply to the return? Or should I really not worry about it? There are 3 radiant panels on this one-pipe circuit.
Thank in advance!
Thank in advance!
So, the only constriction
is at the connections. I wouldn't worry about it as long as you don't exceed 15,000 BTU's for the 3 radiators.
Since it's a series loop, make sure you have accounted for the lower water temperatures at the downstream radiators.
Thanks a ton for the info. The 3 radiators are at about 9500 BTUs, which includes oversize compensation for the final radiator.0
- 86.5K THE MAIN WALL
- 53 Biomass
- 95 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 156 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 928 Plumbing
- 6.1K Radiant Heating
- 384 Solar
- 15.1K Strictly Steam
- 41 Industry Classes
- 48 Job Opportunities
