whats the lowest water temp for oiled fired
D lux_2
Member Posts: 230
120,000 Burnham thanks
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=169&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
Are you looking
for the lowest permissable return water temperature that the oil boiler will want to encounter or the lowest water temperature that cast iron baseboard will operate with? Clarify please.
Glenn Stanton
Burnham Hydronics0 -
the
return temp thanks
We always advise
trying to maintain a return temperature to the boiler of 140 degrees or hotter with our boilers. This will help eliminate any possibility of condensation or thermal shock from occuring. Hope this helps.
Glenn0 -
helps a lot
I didnt know if 140 was just for gas thanks
- 167 Indoor-Air Quality
